combat grunt
Hello,
I installed a S&B 55Gal Tank on my 2022 Ram 2500. I was able to get the fuel tank size reset but the fuel gauge is not working or the DTE as is should. For example it shows I have 1,000miles remaining I have already went 400 I do average 18-20mpg (HWY) most of my driving so the math still don't add up. Has anyone adjusted any other setting to show the gauge correctly? I figure every 13ish Gallons I should move a QTR Tank on the gauge. At this point I'm still showing over full and have the setting for fuel tank size set at 50gallons in size or 189L (DTE did adjust up), I tried adjusting it to 208 DTE moved up but did a test gauge only moved off full just barely at 500miles.
