Rust
A4Owner
I found a 1500 Ltd., that's dropped in price quite considerably. My question is whether these things will (already) have rust on the frame and key underbody components when and if I take possession, and is there a priming technique that functions to remove the rust before any rust proofing treatment I would buy post purchase gets applied...or am I screwed, and is the only way to ensure you protect your truck from rust is to order brand new and rust proof if the day it gets off the delivery truck?
What year is the Limited? Probably doesn't have extensive rust. I bought my '22 in September and finally put Fluid Film on it today. I was a little sursprised to see how much rust I had at 2750 miles. Some areas on the frame and quite a bit on the back rear. Good thing I protected it when I did!
'22 but I think my question is more around do you have to prime or clean the admittedly small amount of rust that the vehicle would have on it prior to FF application.
I will say this, it's almost nuts to buy a new vehicle in Ontario given the amount of salt that gets dumped on our roads. Sucks...
A lot of these trucks come from the factory with surface rust on parts of the frame and rear axle already. It's nothing to worry about really. Even if you live in an area where they salt/brine the roads, a good wash a few times a month during winter and a really good decontamination wash in the spring after rain cleans the roads goes a lot further than some rust proofing coatings.
How do you do a decontamination wash? Are you saying hit the underside with fallout cleaner then blast that off with a power washer?
Get under the truck with fresh water and make sure to get up in all the nooks a d crannies, especially around f the wheel wells. Remove rear wheel well liners and get behind them. Spray inside the frame. Pressure washer may not help due to restrictions of getting the wand where you need to. I just use a hose and nozzle. Get more water flow through way anyways.
If you live in the rust belt area, Detroit, Chicago, Wisconsin area, ect... PLEASE spend the extra money and undercoat your RAM when purchased new!! I love rams, 20 years ago the body would rust bad and engine and trans would last forever, but now surface rust on brand new vehicles is crazy and unacceptable. Surface rust is like cancer... it creates streaks, then spreads to the frame and body and then when you finally notice it, it's too late and the damage is done. I had to show Linex areas they missed when undercoating, bc I looked at used vehicles undercarriages and areas not coated rusted very badly, I'm talking new 2019-2022, long story short....I sprayed fluid film after their job was done twice anyway because spots were still missed. I'm keeping this for 30 years or forever so I'm doing my best to protect my investment.. Below are pictures of new vehicles with surface rust! If purchasing used.....look at the undercarriage, because any detail shop can make the interior and exterior body look awesome but they cannot hide rust underneath. Don't let this happen to you!! In a couple of years the whole underneath will be coated in rust... I seen it on the Rams in their used car lot!! LOOk brand new Ram!!!
People can't pay 60-80 grand and have a rust bucket! And Amazon sells this undercarriage pressure washer; do this in the spring when the temperature goes up because this is when the salt is really activated and does the most damage!Screenshot 2023-02-11 10.48.55 AM.png
20230112_091051.jpg20230112_090840.jpg20230112_090854.jpgScreenshot 2023-02-11 9.57.48 AM.pngScreenshot 2023-02-11 9.54.47 AM.png
People can't pay 60-80 grand and have a rust bucket! And Amazon sells this undercarriage pressure washer; do this in the spring when the temperature goes up because this is when the salt is really activated and does the most damage!View attachment 151424
View attachment 151417View attachment 151418View attachment 151419View attachment 151420View attachment 151421
Great advice if you plan on keeping your Ram. For those living in areas mentioned and with older (now going on 5 years) check out your spare tire also. My spare has been showing rust for a few years now.
My 2001 Dodge Ram is doing fine mechanically but is a rust bucket all over the place. Hopefully I can do better paying attention to the 2019.
Yup 100% right Jako, sprayed mine like crazy with fluid film, lts good to lower it every year, clean and spray where it rest and fluid film on the wheel!! Thanks :)
No issues with rust if you take care of your vehicle and wash it properly. No need for undercoating
Same here, fluid film, surface shield or something similar. I'm sure how the wheel holds up depends on conditions that it is exposed to. Mine has not been too "exposed" in 36,000 miles. Do believe Ram can do a better job on the finish for the spare.
I live in SE Wisconsin and when I sold my 2011 Ram 1500 Sport (plastic front facia) in 2021 with 179K miles it had no body rust top or underneath, and little to no drivetrain rust underneath. Yes, it was winter driven. The guys that bought it couldn’t believe how clean it was when I had it on my lift for them to inspect.
After every snowstorm or period where the roads were wet salted and then dried and was clear, I went to the quarter car wash and cleaned the underneath of the truck as well as spraying the body using their high pressure wand doing it myself. Using the same method with my 2022.
That's all it takes
