tiny4321
- Jun 5, 2021
Ok Im brand new to the forum after 9 years as a Ford F150 owner I traded in my 19 F150 5.0 4x4 Crew Cab for A 2021 1500 Laramie Crew Cab 5.7 etorque 2wd truck purchased with 35 miles on it two weeks ago. So on the third day after purchase I turned on the cruise and set the cruise just fine holds speed just fine. I entered a slower speed zone and pushed and held the set- button and released at the desired speed but it did not set itself at that speed just kept decelerating. I hit cancel and turned off the cruise and back on. I pushed and held the set+ to get back up to speed and released it at desired speed however it kept accelerating to 70 MPH until I tapped the brakes and shut cruise off. Somewhat concerned at this point and the wife was beside herself. Next day I took it out to a rural highway with a good straightaway with little traffic and tried to replicate the the issue. Cruise on, set speed just fine, held down set+ button for 3 seconds until acceleration started and released this time it accelerated to 80 mph and held that speed of 80. I began approaching traffic and braked deactivating the cruise set. I made a second attempt following the same scenario. On this 2nd attempt it accelerated to 90 mph and held there. I pushed and held the set - button and when released it kept decelerating down to 55 where it self set at the first speed I set it at at the onset of this test . As I entered town I came to a 45 zone and held the set- button again and released at 45 with no set it just kept on decelerating as if it had been turned off. The Icon was still showing as ready on the display. I have not had a chance to get it to a dealership yet. The cruise works as it should if you just push the set buttons for a moment and they will add or decrease speed in 1 mph increments if you just push either of the set buttons momentarily. I checked the manual and they are definitely not operating as the manual states they should. I am not looking for a solution I am just wondering if anyone else has had any similar issue. The area I test drove this truck in was congested and curvy so I did not use the cruise on the that test drive. Lesson learned, check Everything on the test drive before buying any vehicle.
