Rough ride
Farmhandz
Fitted Eibach adjustables at the front 2yrs/20k miles back and had the height set at 1” above std as I prefer a slight rake.
Had 33 12.5 22’s on at the time. Noisy but showed good, even wear at recommended psi.
Recently fitted 275/55/20 Bridgestone Ascent AT’s in an attempt to lower road noise and smooth things out. Dissatisfied, I fitted 275/60/20 HT Alenza’s hoping the 60 profile and HT tread would do the trick, but to no avail.
It feels as if there’s zero damping up front. Every little crevice or bump feels harsh, although directional stability is perfect. Steering is tight. I’d like to think suspension is good as I can’t detect any clunking and am thinking the shocks are no good.
I hate to say it but my buddy’s King Ranch rides better - how I’d expect my pickup to ride.
Current mileage 76k miles.
Original steering and suspension components.
Any ideas?
Different approach to adjustable shocks only?
I prefer a smooth, quiet ride - No off-roading.IMG_0097.jpegIMG_1041.jpegIMG_0908.jpeg
Wish I had 275/60 Ascents rather as they look good.
It shows 34 - 38 psi when cold.
Almost commited to 4 new Bilstein 5100’s yesterday.
Still deciding
I had Eibach coil overs for a couple months then got rid of them. The ride was crap, worse than the worn out OEM Hitachis.
I have Eibach Pro-Truck struts/shocks...using 1" ORP springs (matched to OEM) on Front set on Clip #2 (0.6") for 1.6" Leveled Lift, and using OEM Rear springs (RR cut 1 full coil off to level RR/LR) with Airlift bags at 5psi.
I have Front swaybar Energy Suspension Poly-E 36mm bushings and have a Progress Technologies 25mm Rear swaybar set on Tight.
I'm running OEM 20s with OEM Deuler H/Ls at 39psi...and the ride is near perfect as possible for a cheap setup!
If I'm being 100% honest, swapping to Fox 2.5 PEs would give that last bit of perfection..but that's a $4000 hole I can't justify just yet.
I did just order Fuel Variant 20x9-1mm wheels..29.8lbs, HC rings, TPMSs, but deciding yet on 275/60R20s (Firestone Destination AT2s..42lbs) vs 285/60R20s (Bridgestone Dueler Ascent ATs..54lbs)..the weight is my hang-up...OEM~72lbs, FD~72lbs, BD~84lbs
I find the Eibachs (and others that have the Bilsteins) a really good overall upgrade to OEM at a very minimal cost.20240909_141037.jpg
  • Back
