Rims
drixm2001
I bought new 18x9 rims with 0 offset for my 2019 Ram Rebel from Custom Offsets. They guaranteed fitment. When tire shop tried to install, rims won't completely seat on hub as they hit and rub brake caliper. Anyone else have this issue with aftermarket rims?? Any suggestions on rims to buy that will avoid this issue!!
Yes, don't use 18's as they are hit or miss. Obviously reach out to Custom Offsets and and have them correct the issue.
18s are fine as long as you buy what has been proven to work. you are not the first to buy stuff from custom offsets and then end up having problems. if anything, you should go straight to the manufacture and buy direct instead of going through a 3rd party that obviously has no idea of the fitments of what they are selling.
my thread details the wheel and tires used, methods, and why:
im curious what wheels did u get?
methods hub bore is Hub Bore: 108.00
@drixm2001 curious what bore size your wheels are . im also looking at getting wheels and would like this info for futuer reference
Any feed back bud?
I have 18s I bought from Discount Tire. They fit but are close. They have to be careful when balancing or the wheel weights rub the calipers.
