RF Hub blocked after country code change, ¿restore with alfaOBD?
Toni Pal
With an Autel MP900TS I changed country code to Europe, that´s not what I wanted to do but the Autel option was badly named.
After that I get an Auto Emergency Brake disabled warning. And passive entry, remote start, auto high headlights are all disabled.
Returned to USA country code but all issues continue.
Then I bought an OBDLink EX and AlfaOBD, first of all I made a backup (too late but in case it gets worse).
I have tried read and delete DTCs, reset and hard reset ECUs (BCM, ABS, RF HUB...) but nothing worked.
I discovered by using the AUTEL machine that the RF HUB is blocked because of the country change, it says RF HUB blocked after IAC writting
I tried several options to unlock RF HUB module with alfaOBD but all failed.
Inside the RF HUB module I tried RF HUB reset/restore but it was locked with pin and read pin function failed.
Then I remember I had read the pin to add a new fob (with an Autel KM100, I suppose it´s the same pin).
Used that pin in RF HUB reset/restore and another failure, now it says fobik must be programmed before.
Now I have two options, program ignition fobik highline system and baseline system, not sure what I have to use.
Also tried inside RF HUB module, clear multi-module vin handshake inmobilize failure, but it fails too.
Also have done BCM exit from shipping/logistics mode.
I don´t know what more I can do to restore RF HUB and solve all problems I have, any help will be welcome.
PS: my truck is a 2022 1500 DT and I´m using the bypass cable
PS2: also asked for support twice at alfaOBD email but I didn´t get any answer
