rightonbracket
- Dec 11, 2019
If you need to replace your stock truck bed brackets to install a tonneau cover, we have an option. We designed steel right angle brackets with mounting holes that match up perfectly. These brackets don't have a reinforcement bar, so you're able to install a tonneau cover or add other accessories easier. We have replacements ready to ship. Check them out:
Here are the specs on our replacement brackets:
5th Gen RAM Truck Bed Replacement Brackets - Install A Tonneau Cover
Replace Stock Truck Bed Brackets To Allow A Tonneau Cover To Be Installed - USA Made Steel Right Angle Bracket - 5th Gen RAM Truck Bed Replacement Brackets.
rightonbracket.com
- Width: 2 1/2″
- Thickness: 3/8″
- Length: 11″ x 11″
- Mounting Hole Width: 1/2″
- Hardware Not Included. Use hardware from your stock brackets.
- Powder coated black finish
- All edges are ground, buffed, and smoothed on the edges to eliminate any burrs
- The leading edge is beveled to eliminate the blunt edge.
