Replacing exhaust
Jccap83
Hey fam, did any of you replace your stock exhaust with a new system and not have to use a lift. I saw the driver side is a pain to remove. The only videos I saw people had their truck on a lift. Thanks
I think you can get away without a lift but the pipe crossing over to the drivers side is welded and needs to be cut to remove easily.
I did mine without a lift, but I had to cut the driver's side pipe.
I was able to jack my truck up as high as possible on the jack stands and didn’t have to cut anything
