Replacement tires for 23 limited
Rico1964
Brand new truck - I want to replace the undersized 285 45 22 - will 33 x 12.5 x 22 fit without a leveling kit or what has been or is the go to replacement for the 22s without altering the suspension - I cant stand the current low profile look of the 285 45 22s - Thank you Paul
CHeYeNNe71
Sh*tcagoland, IL
305/45 many have swapped 32.8X12, even when lowered. Some have put 285/55 stock, with slight rub that a heat gun will cure in the wheel well.
Rico1964
I looked at a Toyo AT3 285 55 today - I like them was worried about the fit - but I have a heat gun if ts a minor rub
CHeYeNNe71
Sh*tcagoland, IL
Josh24
The Toyo's are great, I've have had the same size on my limited for about 9 months now without issue. They rub occasionally but not enough to really bother me.
