Replacement for Falken WildPeak AT3W?
Couchsachraga
60k miles ago I gave up on the AT3wa that came with my '19 Ram 1500 ORP and went with the AT3w a little apprehensively given my AT3wa experience, but the "W" variant has been an awesome tire. Unfortunately they've discontinued them, and I'm not sure the "new and improved" AT4 is what I'm looking for. I've read through a bunch of posts and completed a few searches but after reading so many figured another wouldn't hurt;) . So if you have any experience, thoughts, or have done this search yourself recently I'd appreciate if you'd take a few minutes of your time and share your conclusions.
The important data:
'19 Ram 1500, ORP
18" rims
air suspension
Leveling kit (spacer in front, plus adjustable link rods)
New England; I do a fair amount of driving in the snow, some mild "off-roading" (site work around the farm), and pulling trailers a few dozen times a year moving my tractor, skid steer, or other random cars or equipment around , not to mention dump trailer (11k+ tow capacity... and I use it).
Years ago I almost purchase the Cooper AT3 XLT, so I guess those are still in the running (they were unavailable last time around), but I'm curious what else is out there and what experience folks have had.
Right now I"m running the 275/70/18's (roughly 33's, same a stock on the Rebel). I'd go fro a "34" if I could find one. 35 would look great, but I worry about reducing my torque for towing and have to admit at this point in life they are less likely to be used to their potential than 20 years ago (more work and less play these days)
In order of priority:
Winter and wet traction
Reasonably quiet ride (these are AT tires...)
mud traction (I'm well aware the trade off of quiet vs. off-load traction...for this vehicle a quieter highway ride trumps mud)
Reasonable tread life (40-50k)
Thank you for any and all thoughts!
I replaced my AT3W’s with AT4’s and they have been great for me. Wet traction is very good. They have some noise, but I also went to a 305/55/20 with zero offset wheels so that could be causing some of it.
if AT3w worked well for you then AT4w wouldn't be any worse.
i've installed many sets of AT4ws for customers and never had complaints.
my next set will be Toyo RT Trail since I've heard many good things about it vs AT4w but winter/ snow aspect probably won't live up to your expectation.
Thank you both for your reply!
Now I have to decide if I go AT4w if I stick with 275/70r18 (33.4") or move up to 285/75r18 (35", and a bit wider), despite me commenting on not really needing 35s;). I noted they have a LT285/70, but they appear to be load range C and I've run E so far, which is likely a better match for the towing I do occasionally and the sticks and stones around the property. boogielander - any thoughts on 35" on stock wheels on an air suspecting ORP with minor leveling kit? Last time I looked at tires it seemed folks were making it work.
Just went over the specs and noted the 285/75-18 are almost a hundred more... a tire. For $400 and less weight I guess I'll stick with try 33's!
I just installed the AT4W and they feel the same and quiet like the AT3W. No winter experience yet with them, but if anything like the AT3W they will be great!!
I ran 3 sets of at3w on my F250, most recent is a set of at4w. The 3ws easily got 50k plus, the at4w have 30k on them, and are hurting. This is on a 600hp 10k truck, so tires take abuse. I loved the at3w, not impressed with their replacement. Put a set of the Yokohama AT XD on my other F350 and 15k in they still look brand new. Ran them through Montana, Dakota all last winter, excellent traction tire.
I recently put a set of the cooper discoverer at3 on my 2500 laramie dsl. much smoother and better traction than the transforce oem's.
