Replacement air suspension boot ?
pdav
Hey I have a damaged air suspension boot on the passenger side and cannot find a replacement (2022 ram 1500 limited). Anyone else able to find one? Anyone know if the 4th gen boot will work for a 5th gen? There are some aftermarket 4th gen available
Thanks in advance!
to answer my question yes 4th gen air suspension boot will fit 5th gen air suspension boot. Bought one on ebay listed as 4th gen.. $20 shipped from china. looks identical and has the same dimensions. seems to be decent quality.
and yes you can make the smaller end fit over the strut fork. no need to take the whole assembly apart. trick is to heat up the boot in some hot water to be able to stretch it slightly
will put up some pics later
I'm thinking a guy should buy a couple of these just to keep on hand in case of a failure. How long did it take to get from China?
Also, what was the nature of the failure?
