Removing tow hook covers on 2025 models
millerbjm
St. Paul, MN
Had anyone successfully removed the tow hook covers in a 2025 without breaking the retainers? Previous years had 2 small screws on top and small retainer rings on the bottom studs. The 2025 appears to have a screw on the top right (when looking from the inside) and 3 plastic retainers on the sides and bottom. These clips look like a plastic tab with a lip that you would press down to slide through the slot but there is no place where the slot would allow that. I may have to break them after removing the screw up top but prefer to keep them intact for reinstallation if I decide to return the truck at lease end etc.
