jljbtm
- Feb 3, 2021
So this story starts with a "no start condition" . I had all the conditions of a dead battery or a bad starter. After checking the voltage it wasn't a bad battery but the starter wouldn't crank so I remove the starter and bench tested it and it worked fine after reinstalling it it still would not start and after tracing down the ground connection to the engine I found that corroded and cleaned it and then the truck started. However after I fixed it I went and cleaned other ground connections including the battery and there is a small black box connected to the negative battery terminal that is held on with a nut yours may have one also so I disconnected that cleaned it and when I put it back on I got a large Spark now I notice my computer screen does not work completely maybe that voltage jolt screwed up my screen does anyone know what that little black box is for on the negative cable.
