390hemi
- Oct 11, 2019
That looks great! thanks for the infol've had the recon unit's before and would say putting a wrap on your 3rd brake light would be better than the recon unit... those recon led's are really not as bright as replacement led bulbs for the stock unit ... l have also had the led boards fail on the recon unit and after the year warranty, meant purchasing a new unit again ... and they are not cheap ... l have the 3rd brake light wrap with cargo lights open ... you can go straight wrap and would look pretty much light the recon unit ... pic below of the tail and 3rd lights ... also going to have the turn signal lights cut open on the tail lights as well ... like the open look versus full wrap
2nd pic is of Ellisstrong's lights
Looks great. What brand wrap did you use? Also, how are the holding up? Thanks in advancel've had the recon unit's before and would say putting a wrap on your 3rd brake light would be better than the recon unit... those recon led's are really not as bright as replacement led bulbs for the stock unit ... l have also had the led boards fail on the recon unit and after the year warranty, meant purchasing a new unit again ... and they are not cheap ... l have the 3rd brake light wrap with cargo lights open ... you can go straight wrap and would look pretty much light the recon unit ... pic below of the tail and 3rd lights ... also going to have the turn signal lights cut open on the tail lights as well ... like the open look versus full wrap
