Recharging Air Suspension
RokTT
What's required to charge the air system? I have Nitrogen tankwith a regulator. I also are using Alphaobd. What adaptor / special fittings if any are needed to fill the system? Where is the system filled from? There is a manifold on the passenger side above the frame behind the rear wheel. Looks like there are 2 fittings there. Any help is appreciated. THANKS
