RECALL: 2020 to 2023 Ram 2500/3500 – Transmission Fluid Leak May Cause Fire:
Standard-Output Cummins Models With 68RFE Transmission...
Stellantis (FCA US, LLC) is recalling 248,342 units of its Ram 2500/3500 Heavy Duty pickups due to the possibility of a build-up of pressure and heat inside the transmission that may result in a transmission fluid leak from the dipstick. The leaking transmission fluid may contact an ignition source within the engine compartment, increasing the risk of a fire.
RECALL: 2020 to 2023 Ram 2500/3500 – Transmission Fluid Leak May Cause Fire: - HD Rams
Stellantis (FCA US, LLC) is recalling 248,342 units of its Ram 2500/3500 Heavy Duty pickups due to the possibility of a build-up of pressure and heat inside the transmission that may result in a transmission fluid leak from the dipstick. The leaking transmission fluid may contact an ignition...
hdrams.com
