Rebel X Leveling Kit
Smon222
Just purchased my first truck (Rebel X) and I had a question about the suspension. I want to simply level the front out and do it properly so I do not mess up towing or off-road abilities.
Is the suspension the same as the regular Rebel, I am getting confused with the 1" lift, and read something about Rebel X springs being closer or something.
If you know, please help me out a truck newbie so I don't get the incorrect parts to do it right.
Has nobody done modifications to their Rebel X yet? There is a lot of conflicting/confusing info about this truck's suspension. Had one company say the new Rebel X spring rate is different due to the new Hurricane engine being lighter. So their Strut & preloaded spring would not work properly and be rough due to the spring rate for a V8.
Is there just a simple 1" spacer to keep the existing shock/spring? I mean for a single inch of lift, it seems like a lot of hassle/expense. Would the geometry really be that thrown off and screw up the ride?
I know there is a difference with the Hurricane vs the Hemi as far as front suspension is concerned, as far as finding any info on mods/upgrades, they are far and few between at the moment.
see if their suspension package is being used on the V6. if so, then it's gonna be the same.
at the very least, it is the case for king. they use the same spring rate for V6, v8, and eco diesel trucks. i know because i called while installing for a customer and i wasn't sure if i needed to adjust the preload on account for eco diesel engine, and the guy at King said they use all the same thing.
also, avoid doing spacers. any shop worth the money will tell you the same. you can call king or fox and ask them.
