SgtSlaughter
- Mar 9, 2025
Looking for some advice/info on rear springs for the Rebel.
On stock springs my front with fox 2.5's is about an inch taller than the rear. When my bed is loaded and my rooftop tent is on, I'm running the Carolina Squat and towing was basically a no go.
I tried gladiator triple rate coil, from Clayton which are 159lbs/in, 280lbs/in and 360lbs/in for the final rate and a .5 inch spacer which brought my rake back. But now loaded, im sagging below the front again.
Im thinking about trying the 3.5" lift springs from Clayton but the different is only the tender spring rate of 190lbs/in
Ideally im using the truck for overlanding so street comfort isn't a priority but it would be nice to be able to load up the bed and not have to worry about bottoming it out.
So what are some good spring options?
I have probably 500lbs of gear loaded when we head out, plus passengers.
Or what is the stock Rebel speing rates?
