Mikejones11
- Aug 14, 2020
To start yes I did do a search and could not find the answers i wanted. From what I understand is the rebel is 1 inch taller than the standard 1500 4x4 due to its springs.
1. So when you order a lift kit are the lift numbers posted based on a standard 1500? I.e a rebel will get 1 inch less of lift?
2. If you order a lift kit that adds the spacers on the coil spring and strut will you get the full 6 inch lift?
3. Need feedback as I am looking at these 3 kits, I want to run 37x12.5x20, going to order either 20x9 or 20x10's
A. RC standard 6 inch strut spacer lift
B. RC upgrade 6 inch lift with replacement struts and rear coil springs (not the coil over option)
C. Zone 6 inch lift with Fox rear shock upgrade.
