Rear Window Leak
rrlorentzen
Minnesota
Anybody else have a dealership tell you to use insurance when their caulk job failed to seal the rear window? When the dealership told me that I immediately called ram customer care and they told me the exact same thing.
There's a TSB for issues with leaking. I just commented on another post earlier today.
You are correct, I printed it off and showed it to them. They gave me the same response, use insurance. Ram claims that the warranty extension does not include replacement.
Ummm that's how a warranty works. Sounds like time to talk to a lawyer. Many have had them replaced. They want you to just walk away. I'd push back.
RAM CARES PLEASE READ THIS !
they were replacing them, i believe after thousands of replacements they stopped.
my dealer was going to replace then they changed to reseal. it's BS. the window frame was cracked that was the leak.
is it really worth losing repeat customers over this RAM? pushing it off on insurance is a trash move. truly there is a HUGE profit margin on the trucks replacing the window is a small price to pay to keep customers buying your trucks. it's either your window supplier that made a substandard product or your assembly process that caused the issue. how has that become a problem for our insurance company's?
i was a chevy guy but i have had 3 ram's and 2 caravans, don't worry you won't ever have to deal with me again. Ford's looking better everyday.
RAM makes a nice truck but there is alot to be said for customer service and the way we get treated after buying big money 1500's is not good at all.
to name a few common issues-bubbling dashes, bad generator bearing's, cracking manifolds, driveshaft slip joint (really) and leaking windows on the back wall where the E-torque battery is and other expensive electronics.
Do you know if any of those people asked for reimbursement and were able to get it? This is the link I see in the warranty notification: http://www.fcarecallreimbursement.com/
Most of the people who have done this did it after the factory warranty expired. You won't be reimbursed by Ram if you swap to the solid rear window because your truck didn't originally come with that. Extended warranties don't cover this but some people have successfully negotiated replacement and received either partial coverage or they covered the whole thing after the factory warranty expired. But I suspect most of those were on the dealership's dime as goodwill fixes.
It's ridiculous how Ram has handled this fiasco, but not surprising. Good customer service isn't what Ram/Dodge/Stellantis are known for.
