Rear Spring Spacers
wiendog
I have a question on the pros and cons off bottom of the spring and top of the spring rear spacers. I have recently added a 2 inch top off the spring spacer with a Ready Lift kit and ORP rear springs to my 2019 Ram 1500 Quad Cab 4x4 . the end result raised the bed of my truck 4 inches above stock to26 inches center hub to fender well.It is too much for my stock non ORP shock I have a 1 inch bottom of the spring spacer and have considered swapping out to lower the rear an inch to hopfully not over extend the rear shock.I suppose my question is the below spring spacer good or should I look for another top of the spring spacer at 1 inch.
Bubba33
I did 1.5 rear spacer under spring. It was right about 1.5 lift.
Scjon03
I did a 1" Motofab rear spacer under spring and it did exactly 1". My truck also has the ORP too.
Gumpa
Minnesota
These on ebay worked fine on my 2019.
streetrays
The Motofabs were not available when I needed them. Price is good too.
antwon412
The ones I used before my longer coils were found on Amazon for about $35
