Rear Outlet - Constant Hot ….How?
dumbazz42
Hi,
I have a 2022 Ram 1500 Longhorn.
I would like to get the rear outlet to be set to always be hot….not just when the ignition is running.
I found a method that seems to work on older Rams (Fuse 90 - 91 swap),….but the fuse box on the 2022 doesn’t seem to have this option.
Any insight is appreciated. Thanks!
You can't do it by setting a fuse.
