Hi all, anyone familiar with the rear axle on a 2019 REbel with 3.92? Looks like a C clip axle. I seem to have a bent rear passenger.
Done some jeeps, is it as simple as
- remove cover/drain fluid
- remove cross shaft bolt and slide cross shaft out
- Remove wheel, brakes...etc etc
- get Clip to drop and remove
- slide in new shaft (looks like the bearing and seal are in the axle not on the shaft.
- Reverse order and include limited slip modifier in fluid
sound about right?
sound about right?
