Ready lift 3.5 SST question
Skelly387
So I had a ready lift 3.5 kit installed the other day. It looks like the shop didn’t trim the strut studs before install. Is this something I need taken care of right away or can it wait until I can get back to the shop? Thanks
I used the same readylift spacers and no trimming was required. I assume trimming is only required if the factory Studs are extending above the top of spacer. This would then not allow the spacer to sit flush against the bucket the strut attaches to. Do your Studs extend past the top of the spacer?
It looks to me like they extend just a hair above the spacer. Not much. I can’t hardly tell without taking the wheel and tire off. The stud is definitely touching the bucket you are talking about
