Ram side step question
rshouse
I have a set of side steps I am looking for a part number for. All I have is a picture of the yellow sticker on the steps. None of these number appear to be the part number. Any idea if there is a way to find the part number based on this tag? There appears to be a set that is aluminum and a set that are polymer trying to determine which set I have.
View attachment 104648View attachment 104649
Hey, sharp truck in Billet Silver!! That yellow tag is the supplier's part number as those are installed at Ground Effects Limited across the street from SHAP. The numbers on there are the date code and most likely the order number to the outside vendor for tracking. I can't read the number in the stamping well enough to make that out. What I would do is tap on the bottom side of the running board with a piece of wood. If it has a "ring" to it it's aluminum. If it makes more of a "thud" it's polymer.
