Ram lift and tire question !!!
1MEANREBEL
I just got my 2021 ram rebel, and I’m looking to do a lift and tires... the one question I have is
If I do a 3 inch lift with 37 inch tires, will that rub at all or will it be fine ? I’m new to this whole truck thing honestly
Welcome, most folks that I see doing 37” tires are usually on a 6” lift.
So do you think with a 3 inch lift 35 inch tires would fit best
Lots of videos on YouTube.
For some reason the 2” Mopar lift doesn’t work on Rebels. Not sure exactly why or who has tried it to find out.
The smallest lift for the Rebel and 35” tires I’ve found is the Ready Lift 3.5” lift with new upper control arms.
The 1500 non-rebels with the 2” lift, 35” tires on 22” wheels look incredible. Exactly the look I’m after on my ‘19 Rebel.
The 1500 non-rebels with the 2” lift, 35” tires on 22” wheels look incredible. Exactly the look I’m after on my ‘19 Rebel.yea
Yea I did some research too and I’m most likely going to do the ready lift 3.5 inch lift with 35 inch tires
Just be cautious with putting the 3.5" ready lifts and other puck lifts on the rebels or the ORP Ram 1500s. This can put the CV axles in a pretty good bind since the rebels and ORPs already come with a 1" lift. I put on a 3" Fabtech Coil Over lift on my 1500 with the ORP which did away with the factory one inch since i replaced the factory coil over. Got about a 3.5" lift once things settled and I run 33s which it should fit 35s but with the 13.50 width and slight offset wheels it does rub still at full turn a tiny bit. 37's you'll definitely need a bigger lift.
I have a 3.5” Readylift and just put on some 22x10.5 BMF Paybacks. I did not have to trim anything and don’t rub
I just ordered my lift kit for my 2020 Ram 1500, BDS coil over 6" kit on a set of Hostile Sprocket wheels (20x10 -19 offset) wrapped in 37x13.5 Nitto Ridge Grapplers. I also ordered the bushwhacker fender flares but gonna see how it looks all set up before I install those. It should all be done within the 1st week of Jan, depending on delivery times
BDS 6" coilovers on 37x20 (-18)
Had to nip and tuck a bit of the back side of the front fender wells. No rub when parking/on the street/etc, but it still rubs a bit when you're getting on it hard in the dirt. One more visit from the cut off wheel and we'll be good. IMO, there's no way you're running 37's on a 3" lift without some heartache.
