Ram Cares doesn’t care or stand behind their word
Shizz1112
I have a 2021 with 42k miles. The heater core started leaking as I could tell by the sweet smell when I turn on AC/heat. Before bringing it to dealer I reached out to ram care about warranty as I knew it was ended but I had an extended warranty. Ram Care informed me that the warranty was expired but the extended warranty would cover part. Now Ram Care is refusing to cover part even thou I have screen shoots of the online conversation. Any suggestions? I am fed up with Ram and Ram Cares. They clearly don’t care.
Snofire
WI
Where did you get the extended warranty? What did the dealer say about the warranty? Other than a chat online, did you call and talk to anyone from where ever you got the warranty from?
Shizz1112
They said the part isn’t covered under the extended warranty
mikeru82
5thGenRams Supporter
The Palouse
Extended warranties vary, but in all of them you can determine for yourself whether or not the heater core replacement is covered. Read through your warranty paperwork. Even 3rd party warranties will list exactly what is covered.
SD Rebel
San Diego, CA
Also, I think you can do a simple block-off of the heater core to prevent anymore coolant from entering your cab while allow you to still keep driving. Essentially the same trick as the A/C hack.
At least until you figure out the warranty situation.
