I watched some online video and apparently RAM 2500 high trims all come with standard 110v power outlet in the truck bed. RAM 1500 high trims should be the same as 2500 which is probably the only thing Ford F-150 does better than RAM 1500
Agreed!I watched some online video and apparently RAM 2500 high trims all come with standard 110v power outlet in the truck bed. RAM 1500 high trims should be the same as 2500 which is probably the only thing Ford F-150 does better than RAM 1500![]()
Again why not have all of the trims come with it, it would be different if you were referring to something actually high end in my opinion.
Because FCA, in all their wisdom, will cut as much as they can get away with it to keep the price down, even if it’s a $5 part that’s actually useful to the end user.Again why not have all of the trims come with it, it would be different if you were referring to something actually high end in my opinion.
