I am in the process of moving full time to my house in northern Ontario where up until recently I’ve only spent the warmer seasons and I’m trying to make sure I am prepared for the winters to come.
My questions are in regards to the engine block heater, battery maintainer and oil pan heaters.
My truck is equipped with the factory block heater which I plan to run on a timer during the colder months of December-March where temps will drop below -40 at times. I figure anytime the temps are forecasted to drop below -15C I will plug the truck in and have the timer set to run for a few hours before my morning commute.
Is an oil pan heater also a good idea to run on the coldest of days? Lets say -30C or colder to help with oil flow?
Should I install an onboard trickle charger to help keep the battery topped off for times where it sits in the extreme cold for days? There’s times where it gets to cold to go outside let alone go for a drive.
I have taken my truck up north during the winter once when it was -29C and had plugged the block heater in just to be safe, truck had no issue starting the next morning nor were there any strange noises from low oil flow.
Fuel stations up there do switch to a winter blend of diesel or even #1 diesel when the temps get really low, I do plan on running an anti-gel during the winter months just to be safe.
Any info would be greatly appreciated. Thanks.
