I've done a little research on adding an amp and sub in my truck , and just want to make sure/clarify what I need. So first I know I have to bypass the ANC using the ANC-CH01? Is there a separate part in addition to the ANC-CH01 so I can make all my splices under the seat instead of getting to the factory speaker wires? Now the powered system I'm looking at does have HI/LO inputs so I wouldn't need a LOC? Just a speaker wire to RCA conversion straight to the Amp? And as far as I've seen my truck shouldn't have a factory amp/sub so I don't have to mess with all that other stuff. Last thing what else would I need if I wanted to upgrade my factory speakers in the future? Thank you!
*EDIT: I see I can just tap into the speaker wires from the ANC-CH01 I believe.
