gnossdrawkcab
- Feb 21, 2021
I'm about to install a Key 200.4 in bi-amp mode and I have a few questions.
1. My dash speakers are 47KSC3504 and I put a 4ohm resistor in line with the positive terminal per instructions elsewhere in the forum. Do I still need this resistor with the key 200.4?
2. The 47KSC3504 dash speakers also have an inline crossover, I believe bass blocker. Should I remove this before running the key 200.4 setup?
3. I plan to run new wire for the dash speakers but I'm not sure what to do for the front speakers. Can I simply splice into the factory harness at the back of the head unit? Or should I connect at the ANC under the drivers seat? I have a netaudio bypass on the way with the amplifier addition provision. Although I'm not sure I need that after reading these posts...
I'm a bit confused as it's my first amp install. Thanks!
