I'm not sure what you are asking. You don't need any of that to use adaptive cruise control. Are asking about adding it? If so, there is a whole how-to that explains everything you need to know in the modification section.Hi there, my name is Ivan from Ontario. Canada have a 2024 ram sport.
Do I need to bypass the security control module when using alpha OBD foradapted cruise on my 2024 Ram ?
Yes, I’m trying to add it. I do have a taser and I have the alpha OBD and I followed the steps for removing the cruise control and adding the ACC stop and go and now I have two warning lights on my dash and says ACC adaptive cruise off any help in this matter would be much appreciated.Yes, you need an SGW bypass installed when making changes with AlfaOBD. If you have a Tazer, that will suffice. Otherwise, you’ll need to buy one.
When I added the adaptive cruise to my truck (using AlfaOBD), it took a couple of ignition cycles for it to “take”.Yes, I’m trying to add it. I do have a taser and I have the alpha OBD and I followed the steps for removing the cruise control and adding the ACC stop and go and now I have two warning lights on my dash and says ACC adaptive cruise off any help in this matter would be much appreciated.
The warning lights are normal right after enabling ACC (Adaptive Cruise Control). It just takes the truck a couple of on-off cycles to figure out that the hardware is there. Assuming the hardware is there. I’m not really sure how to know if your truck has the appropriate sensors. I have a TRX, which was built with all the sensors regardless of options. So I just added the steering wheel switch and enabled it with AlfaOBD. Maybe someone else can chime in as to whether the Sport trim comes with the sensors.OK, I will try that. I am totally new. Any idea what the warning lights mean?
As for all the hardware, how do I reference as to the proper ones?
