Question about right offset
Naldo1
So I have a 2019 1500 bighorn I'm planning to add the factory wheel flares like the limited then getting new rims to give a little stance or more of a flush look so just checking if anyone has done this and what offset worked for u
I'd bet a zero offset should probably put your tire sidewall about flush with the flares. The higher the negative offset, the farther out it'll be.
Go to customwheeloffset and check out the galleries. It'll show you the stance and all the details to go along with the pics.
