NHais
- Dec 14, 2024
Hey guys. I just installed a Pulsar XT on my 21 Hemi etorque and got the P2122 & P2127 pedal codes every time I restarted the truck. Others have posted with the same problem. After checking everything out, I realized that I had installed the power fuse for the Pulsar in the 10 amp fuse location above FU33, which is FU28. When I moved it to the correct location - FU33, everything worked and no check engine lights. I hope this helps.
