SilverSurfer15
- Jan 21, 2019
Finally got this installed, so far so good. A small clunk feel in the steering wheel on certain bumps, unsure what that is. I’m definitely going to be upgrading to full coilovers as soon as something I want comes out. Or MAYBE teraflex shocks set on like 1”. This is the full kit, the angles don’t seem too bad to me. The CV joint on the inside isn’t ideal though, it’s almost like there’s just too much boot there and it’s crunching up. That being said I definitely wouldn’t go any further with it.
Front fender is 46 1/4 and rear is about 45 7/8, it sits pretty level to me. Maybe slightly higher in the front.
Initial Driving impressions: it drives surprisingly good for this type of setup. But anyone who thinks this drives same or better than stock needs to re evaluate a stock truck. There doesn’t seem to be a huge power loss, at least in normal acceleration so that’s a plus. The 3.92s help for sure there. Little bouncy over bumps, your normal crappy shock and preload spacer feel. Tires seems pretty good on the initial run, I don’t even know what psi they are at so should be better once I air down.
Came out pretty awesome I think! I’ll have to clean it and get some better pictures.
