To the OP: I don't know if @Ellisstrong does any towing, but he can comment if he does.I don't have either, but have looked into motor add-ons; in general you should know the limits of your specific drivetrain. Any added power + strain = higher likelyhood of failure.
Obviously, A diesel would be better overall for towing due to torque + drivetrain built for torque.
What 1500 are you running now? 5.7? eTorque or not?
It would help others answer your question if you offered more info, like how heavy are you planning to tow, etc.Anybody running a Procharger or similar super charger and towing heavy loads? I'm thinking about a Procharger instead of upgrading to a 2500 and a diesel. Curious to know if anybody has real world experience. Thanks!
Only towing I do is hauling me and my extra Covid weight around. I would think a whipple would be better for towing since it adds more low end torque. I got a Procharger since the way it delivers the extra power I have less concern with wear and tear...To the OP: I don't know if @Ellisstrong does any towing, but he can comment if he does.
In response to above, the EcoDiesel offers some positives over the HEMI (e.g. better fuel economy, 17% higher peak torque). It also has some drawbacks (e.g. heavier weight, 34% less peak power). The transmission and axle ratios are the same regardless of engine selection. There's probably a sweet spot for the EcoDiesel (i.e. moderate frequency, lightweight towing). For daily or heavy towing, I'd (personally) step up to a 3/4-ton diesel.
Correct on all of this and I’ve heard this transmission is the same one they use on hellcat swapped jeeps so I think the tranny is stout enough to handle almost 600 to the wheelsour trucks would handle 7-8 psi totally fine. Several people have had theirs supercharged and no problems so far. If you want to go above 7-8 psi then you would need engine upgrades and maybe better trans.
