EnzoGorlomi
- May 29, 2024
If I’m installing the Kicker HS10 and I’m using the ANC-CH01 bypass harness, is there any reason I would need the Kicker 46KISL(speaker wire to RCA)? Or, am I just tying the HS10 wires to the ANC-CH01, running the power and ground, the bass control knob, and calling it a day?
Also, I replaced the stock door speakers with Kicker 46CSC6934 6x9, 3 way, 4 ohm. Will they work as is with this setup, or do I need another amp to power them? They sound fine currently.
