Long5449
- May 14, 2025
Had to replace my driver side mirror, switched them out, now front windows won’t function at all. Back windows and both mirrors function as they are supposed to. Check engine light came on. Also plugging the old mirror back in allowed the windows to run too. Battery has a a drain somewhere because it’s acting up. I’ve tried unhooking the negative for 20 minutes. Did not fix the issue. Have not checked the check engine light code yet but it has to be because of the mirror and windows right? Then the Ambient Temperature sensor is now reading 185 degrees. Any ideas? Anyone seen this issue before? Thanks for any ideas to try.
