Power Running Board interfering with Active Tuned Mass Module
jdeilus
I have that message that pops on that reads that my Active Tuned Mass Module is temporarily unavailable. I looked under the truck and notice that the power running board is touching up against the mass module mounted on the frame. Does anyone think that this is causing the message? If so, is there a way to adjust the running boards so they don't touch the module?
Need a bit more detail, OEM or aftermarket running boards? Are they touching the module itself or the harness? If the connector isn't fully seated I could see it maybe getting moved enough to break the connection
It’s Amp Research power running boards. The wire connection is tight. The arm of the running board is touching the module. The message will pop up around 2-3 minutes of driving and will come back on around every half hour. Sometimes I feel a vibration when it comes on
I think there is something that needs to be relocated with the AMP boards, was that done.
That’s what I’m thinking. Is there a way to deploy the board and keep them out while driving? If extended out they will not be touching the module. If I don’t the the message anymore, that will let me know if that was the problem.
