Possible to download and reinstall update?
deeve
Hillsboro, Oregon
My truck (recently out of 3yr36k warranty)had a hard time downloading and installing the latest OTA update. Several failed attempts etc. Ever since it seems to be buggy with freezes, reboots, failed carplay autoconnect and missing buttons. Is it possible to reinstall the update via thumdrive or some other trick to get it to reinstall?
Thanks!
DAVE
Technically, yes, it is possible.
But.
You will need to source the files, as RAM does not provide those files to the general public.
A multi-step procedure will guide you in installing the files. You must follow those steps carefully and diligently.
It will be easier and potentially faster to have the dealer help you in this process. Your wallet may not agree, but when you factor in the time and effort to acquire the files, the time to install the new files, and if there is a problem, the dealer has the resources to most likely solve any issues with the new software install. The error codes that are given during a failed install are not very descriptive as to the failure and solution(s).
BlueHemi1500
