POIs
DennisY
I suspect the answer is no but is there a way to display Points of Interest (POIs) on the NAV while in motion? That is, icons or text that tell you food (for example) at the next freeway offramp. I really miss that feature from my Garmin GPS use days. GPSs will display icons for food, gas, and lodging, and some others if I remember right. (You can also install some custom POIs. I'm not necessarily looking for custom in this case.)
(Yes, I know I can go into the menu, navigate to food (or is it restaurants?), etc. but that is cumbersome and doesn't display the icons on the map while in motion like the Garmin GPSs do.
