passenger window removal
Vpatrol
Evening folks.
Having a struggle removing the window/inner plastic door panel (passenger rear). Ive got a sizable dent in my 2019 ram 1500 door so the window doesn't go down fully to use the 2 access holes. I can flex the panel out of the way to get to the two bolts from above however it appears that the bottom of the window is glued into the plastic clips. It was easy to pop them off on my '14 but not so much here. Tricks or tips?
Advice would be appreciated unless someone wants to sell me a granite metallic crew cab door! Not enough wrecked ones here in Canada. Thanks in advance
