panoramic roof issues
av8gunny
After having a boyscout trailer deplete my trucks battery I find that the three control buttons for my panoramic roof are no longer operable.
How do you reset this system? I have heard different things like removing the c/b, unplugging the control panel and the dealer eventually having to replace the actuators.
Has Dodge come up with a SOP to trouble shooting and fixing this issue?
Excellent question
I would start with disconnecting your battery (for a few minutes to drain any residual voltage from the system) then reconnect it. You had a low voltage condition, and many of the systems in these trucks do weird things under low voltage. Don't be alarmed if everything doesn't immediately come back when you reconnect the battery. It can take a while for everything to reset, but it should all be working after a few hours. You might do this before you go to bed, and it should be back up in the morning.
