Pano roof / head liner rattle/click over small bumps
mike_ct
yone have a fix for headliner/pano sunroof rattle/click noise over bumps? Been battling for a while, trying different fixes. So far - lubes seals with crytox 205, dropped headliner numerous times to secure wiring, tighten speakers, added dynomat/foam around things that seemed loose and might be making noise. New Velcro clips on headliner, and added foam blocks from the TSB. ***if roof is open or tilted, I don’t hear and clicking/rattle.
Could it be the rear/non-moveable glass panel? Sounds like it’s back there. Seems like it is suspended, and surrounded by a foam rubber gasket against the roof metal. Maybe this is making the noise and needs to be removed/lubed/replaced?
I'm experiencing the same issue, I'm curious if anyone has a solution for it.
Just chiming in to make sure it's the pano sunroof that's rattling (and not the rear slider). Do you typically open the rear slider at the same time? There's a known rattling issue on that when open.
