P02C6 code, in 5.7l
magtech
When i pull codes on my 2020 ram 1500 5.7l I keep getting a p02c6. Everything i see online refers to fuel trim.
When searching forums i only see information on ecodiesel.
I tried the search here and it gave me nothing. Am I the only 5.7 guy to get this odb code?
I recently got the same code along with 2 codes related to my active air dam that has decided to fail in the lowered position. Did you ever get any input from others regarding this code?
What reader are you using?
There is no P02C6 listed in alldatadiy.
Could be because we only have 8 cylinders, not 12.
"What Does the Engine Code P02C6 Mean?​
Character "P" in the first position of Diagnostic Trouble Code (DTC) represents the powertrain system (engine and transmission), "0" in the second position means that this is a generic OBD-II (OBD2) DTC. "2" in the third character position in a DTC indicates that the fuel and air metering and auxiliary emission controls is experiencing a malfunction. The last two characters "C6" is DTC number. OBD2 Diagnostic Trouble Code P02C6 means that Cylinder 12 has been detected"
