overhead switch problems
LRojas
A issue has arisen with my 2019 Laramie, the switches in the overhead "console" for the map lights, the mirror dimmer, and the cabin light have quit working, BUT the switch for the rear window still works. I have checked all the fuses that I thought might have anything to do with them to no avail. Anyone else ever experience this? Anyone have a solution?
Malodave
Rindge NH
You will have to pull the console to even start a diagnosis.
There are two screws inside the Sunglass cubby to remove.
Then there are two clips to depress. The console should drop
with two harnesses going to connectors on the console.
Malodave
LRojas
Malodave
Thanks for replying and I apologize for my delayed response, I never got a notice that you replied.
So what do I do after that? How do I diagnose beyond checking that everything is connected properly and securely?
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Start by subscribing to one of the online service manuals.
Alldata DIY is pretty reasonable, has good diagrams and trouble shooting info without breaking the bank.
