Those are exactly the temps I'm getting, which is about right for a full size truck that weighs over 5,000 lbs.
You are talking about 3,700 lbs vs 5,400 lbs or so. Imagine towing with your GT350, with a 1,700 lbs trailer, your temps would definitely go up. Ideal engine oil temp is 200 - 225, and that's ideal, meaning the best temp for performance and fuel economy. Can run a bit higher without hurting anything.
Plus a GT350 is designed with extra cooling in mind to handle the rigors of doing lap after lap on the track, which is far more harsh on cooling than even towing for a truck. Tooling around under low stress should allow your engine and trans to keep even cooler than most normal cars, including regular Mustang GTs.
