Oil Leak-coming from Top
Quicker10u
Savannah, GA
I have done some research on here and am trying to figure out an oil leak on my 2019 Ram 1500. It’s got about 68k miles on it now. The drip is between the trans bell housing and the block. It’s not an RMS as the weep hole is dry. It seems to be coming from the top passenger side of the motor and following a trail down the transmission bellhousing. The valve covers look dry as does the backside of the cylinder heads. MDS solenoid? Intake manifold? Any thoughts would be helpful. Thanks in advance.
I think the MDS solenoids are in the motor, under the intake. Could be intake. Get a small mirror, or stick your phone down to get a picture.
