Oil Catch Can on DT EcoDiesel?
c3k
I'd like to keep the oil out of the intercooler/turbo and the back of the valves. A catch can would help minimize the oil intrusion into these areas.
It's a simple/easy mod on the 5.7. However, I'm reading that there are issues with doing it to 2019+ EcoDiesel. One enterprising individual got his catch can install to work (without throwing codes) by tapping a vacuum line into the throttle body...and doing some other stuff.
Has anyone here successfully, and simply, been able to install and run an oil catch can without tripping all sorts of codes?
Thanks!
this site is only site i saw that makes one for eco diesel
  • Like
Reactions: c3k
Thanks. How will dealership service departments react to seeing it installed? Wondering what the risk of voiding the warranty would be.
Thanks for posting that! That's the first I've seen. I'll look into it and see if I can get it reasonably and, depending on that, install it and see if codes spit out.
ETA: looking at it, it doesn't seem any different than a Mishimoto or the other high-flow catch-cans out there.
I bought a Catch Can, but since I am currently Homeless, all
my Mods have been put on hold until I secure Housing. I am
using a Blowup Mattress at work until I get that housing.
Malodave
  • Wow
Reactions: c3k
same thing i was thinking when i saw it
Heads up to northerners, catch cans separate out water which is good but water freezes so it will become something you need to check regularly if you are in below freezing environments. A frozen line blocking EVAP or the flow of air can throw codes or cause damage and keeping in mind you'll need to empty it often and tell your dealership it's there and argue with them about warranty issues.
2019-2023 RAM 1500 3.0L EcoDiesel Crankcase Ventilation Oil/Water Separation Kit. PPE just made one ! for Gen 3 ecodiesels.​
This is what I bought....ordered and had to wait for a bit until they did a run. Its very very high quality.
Yeah, I put a very similar one in a few years ago. Let me look and see if my thread is floating around... Catch Can for the ecoDiesel without throwing codes?
From T&S Speed shop, but it looks identical?
TS is now EOC. Same stuff and some new stuff but more. They do tuning as well but use MR. If you look at some pics on EOC you can see the T&S emblems on some items. It’s good stuff.
  • Like
Reactions: c3k
I will order one too. It's cheaper than the other one was like $399. This one is like $210.00 plus $40 shipping.
The catch can just arrived itS from TS. I will install it soon. It's made out of hard metal and looks very strong it has some weight to it.
