Offroad bump stops?
boogielander
Anyone has any lead on who makes offroad bump stops that are higher than stock?
Basically something that replaces stock bump stops that offer better dampening when coming off a "jump"
I really don't want to do the king air bumps but if it really comes down to lack of alternative solutions I guess that's the only way to go
Thanks!
King, Fox, TKO maybe. Just the usual ones probably.
The best ones you can get are falcon’s. However I recommend trimming them down an inch for the extra uptravel. All other options restrict travel. You could do some custom kings or foxes. However in my testing your money would be better spent on rear bypass shocks.
This is after they are trimmed. If you check on my thread TikTok you can see my testing videos.
You won’t find them. You have to call Falcon and order them. They don’t advertise them outside their kit. I think I paid $90 for them
thanks yall! I don't mind sacrificing a bit of uptravel if it means i can land nicely with all the crap i have put in lol
Yea easier said then done on that taper. that stuff is a ***** to cut. It should work good now but the backs of these truck could really use a bypass. Even a king 2.5 would work great to control the rebound. Compression is great.
can’t wait to do my fronts
